2004 Ranger flatbed
josh1236
5+ Year Member
West Virginia
I just wanted to show off the flatbed I just got done building and see what you all thought of it!
40885
its awesome!
though i would not have given up as much departure angle. and needs a drawer.
Looks pretty stout...
Any idea what it weighs?
and stake pockets.....and rails for tie down.
Looks great! I agree, you need tie downs of some sort. I would also recommend mud flaps for nothing else than preventing thrown rocks.
its awesome!
I’ll need to figure out something to keep the tires from rubbing when I’m off-road I kinda screwed myself on that one lol
I have no idea honestly. I could carry the main frame of the bed then I welded on the headache rack and the plate on the rear end after I already had it on the truck.
I plan on cutting leftover pieces of my 4 inch channel for tie downs but the only place around here that I can buy flat bar is closed. As soon as I can get flatbar I’m adding side rails and I plan to run wood sides also. I’m going to order a set of mudflaps here soon it’s really bad about throwing rocks.
Little here little there...
Then your building crane mounts.....boom poles...roll-up dumper....
I love it.
Nice! I'm building mine in the next couple weeks.
If you have any questions building yours let me know!
How much did the build cost? I'm on the fence about doing this to my 2007 fx4 level II.
Also how did you mount to frame? anymore pics would be super helpful!
  • 2004 Ranger flatbed
I had around $450 in steel and I probably had $700-$800 in it total. Mine has pieces of 2 inch square tubing that sit on the frame and I just drilled holes to line up with the holes that your factory bed mounted to. I think I used 3/8 grade 8 bolts and haven’t had any issues yet
Nice!
you got any more pictures of the build? or the finished build from different angles? I didn't know the steel would cost that much. What thickness plate did you use? did you bend it all yourself?
Thanks for the help Josh!
