- Feb 6, 2020
- Montana
- 4.0 V6
- Total Lift
- Stock
- Tire Size
- 31” x 10.5”
Hey guys,
Starting an investigation into a pretty decent oil leak. Have redone the upper/lower manifold gasket. The font of the motor (crank area) seams to be pretty clean. Seems to leave me with the oil pan gasket and the rear crank seal gasket being the culprit.
The oil pan gasket will require the removal of at least the two front I-beams. (Maybe I’ll do it when I install the 4-inch lift. The other requires the removal of the transmission (A4LD). Basically I think I am just complaining to you folks about it. But, any wisdom regarding decent dripping oil leaks off of the rear of the oil pan are more than welcome! :/
