need an answer about radiator hoses quick
holyford86
Some guy with a problem
⭐Supporting Member
💻 TRS Socials
Boosted (Not Stock)
Plattsburgh
NY - USA
many
Vehicle
Drive
33x12.50R15
i know its not the right forum but I need an answer quick. I need to know which hoses to use for swapping the 2 1/4 inch thick explorer auto radiator into my 86 2.9 truck, What hoses do I need to use? Do I need to use the 4.0 auto lower hose or the 2.9 auto lower hose? What about the upper?
Dont know offhand, but just get a look at it bud. If the ports are at about the same spot and same size naturally use the 2.9 hose. The hoses typically are routed to go around other crap in the bay, not by the radiator used. If the location of the ports is about the same, just use the 2.9 ones and cut them if they are a bit too long. If not, youll probably need to custom something up.
Good luck.
4.0L lower hose. Carefully trimmed 2.9L upper hose.
You can probably get away with a 2.9L lower hose. The 4.0L upper will not work without amputating the throttle body.
when i did mine on my 89 2.9 i used the stock 2.9 hoses top and bottom, if i were to do it again i would find a little better top hose
There isn't one.
The 4.0L upper intake is substantially different from the 2.9L upper intake. And obviously all 4.0L radiator hoses were designed for 4.0Ls.
i went with the 2.9 lower hose, it fits alright without shaving and it isnt even close to kinking anywhere. didn't even have to bend the hose around much to get it on the radiator. If I start having issues with it I will change it to the 4.0 hose. I am now debating whether to use the trans cooler for the power steering or not since I have a manual transmission. thanks for the replies.
There isn't one.
It's not the intake that's the interference, it's the alternator
and the 4.0 upper hose has to be routed around the alternator
to get to the upper neck that's angled out to meet it.
BTW, I found that the upper hose for a 2.9 purchased from
CarQuest was easier to trim and twist to keep it out of the alternator belt.
I don't have that problem anymore.
I'm using a 4.0 upper hose to connect to my 4.0 radiator.
Of course there is a 4.0 water neck and a 4.0 engine at the engine end of the upper hose.
As for the lower hose the 4.0 Auto trans piece fits perfectly, because it's exactly the same as the '89-up Ranger/Bronco2 auto trans hose for a 2.9.
AD
There isn't one.
i was refering to looking for one from some other vehic that can be trimmed down to fit not using the 4.0 hose
