Non-Ford, Compact Trucks
Ranger_XL
5+ Year Member
Wind Gap, PA
If you were seeking to purchase a compact, pick-up truck aside from your Ford Ranger, which option would be the better choice: the Chevrolet S-10/GMC Sonoma or the Dodge Dakota?
Well, if you need/want (factory) v8 capabilities, the Dakota's your only choice, I really wouldn't consider it compact compared to an s10 or ranger though.
GMC Syclone. 270hp turbocharged 4.3.
Ford never made a Ranger that could compete with it.
You could buy 2 new Broncos and a Super Duty for the cost of a Syclone.
Id probably buy a 1st gen S10 honestly.
before the s10/sonoma or Dakota I would choose a Toyota Tacoma. but I would get it from a southern state as Toyota had some rust issues on the frames.
AJ
If we're going to deviate from the OP's guidelines,
Hilux diesel.
Since I have no idea what you are using it for, I'm going for the Dakota. I had both the S-10 and a first gen Dakota. The S-10 was comfy but I was over working it. (It was a 4cyl, LS model) The Dakota was a basic work truck with an eight foot bed that got horrible mileage (14!) I think a new gen with the proper lower valance would help.
The s10 has a very huge aftermarket selection of parts, not to mention all the Chevy, Caddy, Buick, Oldsmobile, Pontiac, and GM parts that will swap into that sucker.
My other truck is a 88 Nissan 2wd and parts are pretty easy to come by except the throttle body, those are getting harder to find. But a carb will fix that when i get there.
38276
S10 with a 4.3 , just dont drive pissed and hold it to the floor when you leave from a stop, it (may) not shift out of 2nd and at about 70 mph and 2 miles later its pumped all the oil to the top of the engine quicker than it can drain back down to the oil pan- then you spin every rod bearing and it sounds like a diesel afterwards.
You also have to remember that when the intake gaskets go the stop leak goes in the coolant, not the oil.
