Electric turbo
Here you go, only a few bucks.
Grumpaw
I read, a couple years ago, that Mazda was trying to develop an electric turbo that didn't need to spool up, and required an additional power source to deliver the juice to the turbo. Hmmm?
They've used electric systems to spin up blowers to eliminate lag. Not directly for boost as far as I know.
These guys a using them to produce boost with measurable results
Measurable, or efficient? It's been attempted many times. There's a reason no reputable manufacturer sells one.
Well there plenty of people who have dyno numbers to prove it that arnt affiliated with the company.
This guy reminded me of someone
The formula 1 boys have been running hybrid engines with engines using a supercharger "boosted" by an electric motor for 5 years now. Apparently that's how long it took for their electric motor technology to make it to consumer market.
There has been some speculation that one of the manufacturers was getting around the rules limit of 160 kW (214 hp) of battery power addition, by using battery power to spool up the supercharger which wasn't being monitored...
From their graphs, their supercharger will get you 20-25 hp gain for 2 minutes or less. Is that worth $2,500 to you?
Not me but it is still an option for others that I felt wouldnt hurt to add here. It's the tq gains that really stand out
if I calculate correctly at this late hour: :sleep:
5000 watts is about 6.7 hp, and that little motor is gonna get hot real quick.
it's a good thing they use a power pak to bump the volts up to 48, because to
get 5000 watts at 13.5 vdc would need about 370 amps.
even at 48 vdc it still pulls 104 amps.
I'll stick to my ECOBoost.
I thought about using a boat bilge blower (they are a electric in-line blower fan for engine compartment ventilation in stern drive boats) in a car over 20 years ago, worked at a boat dealership at the time and had salvaged all the needed parts from junked boats. turns out those dont move enough air. I was only in my early 20’s then.
Event Coverage
TRS Merch
