"Crankcase Ventilation Filter" is oil separator for PCV system
auto117584
Chapter one and six of the Haynes manual explain it. The PCV valve plugs into the rubber grommet on top of the oil separator. During idle, high vacuum closes the valve and prevents crankcase vapors from entering the intake manifold. This keeps the idle steady. There is a hose somewhere (probably into the valve cover) that puts post-air-filter air into the crankcase. Under unusual circumstances, when there is too much pressure from the crankcase, the PCV closes again, and the crankcase vapors are routed back to the post-air-filter area, where they join intake air for combustion. I'll quote Haynes, ch.6, section 8:
1. The Positive Crankcase Ventilation (PCV) system reduces hydrocarbon emissions by scavenging crankcase vapors. It does this by circulating fresh air from the air cleaner through the crankcase, where it mixes with blow-by gases and is then rerouted through a PCF valve to the intake manifold.
2. The main components of the PCV system are the PCV valve, a fresh-air filtered inlet and the vacuum hoses connecting these two components with the engine and EECS system.
3. To maintain idle quality, the PCV valve restricts the flow when the intake manifold vacuum is high. If abnormal operating conditions arise, the system is designed to allow excessive amounts of blow-by gases to flow back through the crankcase vent tube into the air cleaner to be consumed by normal combustion.
And from chapter one:
...The PCV valve on SOHC four-cylinder engines is mounted in the oil separator on the left side of the engine."
OK, me again. The oil separator is just forward of the oil filter, under all the intake stuff. Haynes doesn't mention any repair/replacement of the item, so I just soaked it, shook it, and drained it, quite a few times. Lots of hardened oil came out, probably a couple spoonfuls, little chips and bits. I blew through it to make sure it wasn't clogged, and it passed my air with no restriction at all. I shook my PCV, too, and looked at the hose, and they had a little oily residue, but the valve rattled, so I will re-use it after I re-install all the intake stuff. Maybe intake stuff will go on tomorrow. Cheers, guys. Hope this clears up the matter.
ive been looking where the darn pcv valve is on these engines,thanx for the info,no use buying a new pcv valve ,when you can just soak it and shake it,lol
PCV valves are cheap and probably the most neglected item in the engine they wear out or get clogged or stick open just change it every other tune up and your engine will like you for it not to mention your wallet in fuel consumption. It directly affects air fuel at all speeds, the breather filter in the air cleaner basically all it does is filter the air going into the engine as the pcv pulls out the blowby and absorbs the oil when the blowby is greater than the pcv can handle so it dont clog your air filter so yea it is putting the blowby thru the conbustion chambers either way.
on the 2.3 it is directly left of distributor hard to see but can feel with hand...comes off easy... i believe larger engines it is back a little farther...
Do not replace a PCV with a cheap parts store replacement on any engine.
Always pay the little bit extra ( pennies to a dollar in most cases ) from the dealer parts counter for the factory replacement.
These little suckers are designed for a specific amount of air flow.
Any more and they suck oil out and into the intake. There goes your valve seats....
Cheap replacements are just that cheap. And never to factory spec.
An example of this would be on my 87 cavalier. Granted its a Chevy and a 2.0 but the same applies.. this is just and example. EVERY TIME... I have tried to use a parts store replacement PCV it starts using oil. I go to GM and buy the correct one it stops.
( even smokes a hair ).
Same for every Ford product I have ever owned as well. ( BII, Escort, Stang, Ranger, Bronco, F250, F150, F100 )
Yeah, but on my 93 2.3 l you can't find one to save your soul. eBay has old used junk for $50 bucks.
  • "Crankcase Ventilation Filter" is oil separator for PCV system
I should start a brand new thread so this info here gets lost and not read by someone new? What if the people who posted here ten years ago had valuable info and have since left this forum? Resurrecting post could be the easiest way for new members to see relevant info to there problem!
Absolutely! Thar's gold in them thar old posts.
I'm on another forum that was getting spammed horribly for awhile. It was great seeing all the old threads that I would never have seen otherwise. I don't see a problem gravedigging as long as the new post is relevant.
I am Fredness, Master Necromancer of long dead threads, and I approve.
