⭐Supporting Member
- Sep 20, 2009
- Dillsburg PA
- 4.0L
- Tire Size
- 31X10.50X15
The limp mode you are talking about just pretty much bypasses everything doesn't it? As in the EGR doesn't work, it don't shut down the fuel injectors when coasting, etc.? It also effects timing advance and that type of stuff as well correct?
I don't know exactly what all is effected. I believe the EGR is shut down. I know the air-fuel calculation goes to pre-set values and the oxygen sensors are basically ignored.
