Sportrac axle in Ranger?
cul8ri1
Winnipeg
I have a 2005 ranger with an open diff rear end 8.8 and 4.10 gear.
My buddy had a spare axle out of a sportrac will it fit on the Ranger?
The numbers on his axle are s663a 4L10 88 OE04
If I just want to swap out my open diff for the lsd diff can I do that? Will the axle shafts fit?
sport trac is the same as an explorer so it would be 31 spline, and your ranger is 28 spline so no the axle it self is not interchangeable, but you can swap the entire rear.
Isn't the SportTrac an independent rear suspension though?
I should have just opened the parts catalog at work.
Pretty sure you will need to flip the spring perches on that for it to fit a Ranger (spring-under). Once that's done, it should fit. You'll need to weld shock brackets on it too.
It is also an inch wider, overall.
He didn't specify the year so i just remembered the one in the shop. I laughed at it. IRS for a supposed truck? People wonder why Ford is a laughing stock in the worldwide auto market. It'll change though.
What if I use the lsd diff from the SportTrac and the spider gears from my diff so that my axles fit would that work?
no exporer/sport trac, 31 spline axles, ranger is 27 spline or 28 i forget.
Its only a 4X2 and I will be driving in harsh winter, snowy conditions so thats why I want the LSD. I didnt get the other one for free I just have a friend who has it from a salvage truck so it would be cheap but not sure on a price yet.
well then try to find a ranger lsd from a wrecked truck, you have to check but i think alot of the mustang limited slips will fit into the ranger 8.8.
