- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
I never said a 3.0 cant pull.I'm going with the 3.0 on all scales. Not sure why rusty doesn't think the 3.0 can pull a load because they definitely can. Mine pulls my 700 lb trailer FULLY LOADED with heavy ass fire wood like nothing. It honestly drives nice with a trailer. I've passed people going 55 with a fully loaded trailer. The only thing the 3.0 lacks is take off but makes up for it with high revs. I definitely want to see a 2.9 vs 3.0 matchup. Doesn't matter if the 3.0 was used in a Taurus as well as a ranger because they used the 3.0 for 17 years for an obvious reason.... It did the job. Once I get the axle swapped it will be ready to go so I could help put some times on board.
It just....wont pull as good as a 2.9.
Plus lets not forget an 86/87 2.9 is likely to be paired with the TK 5 with its pretty low (3.96:1) 1st. This coupled with the 2.9s strong low powerband makes things look real bad for a 3.0.
The 2.9 was killed because it was only used in the ranger by 92, it wasnt as refined as the 3.0, and most people bought a 4 banger or 4.0 anyways.
I had a trailer back in the day with 5 ft sides, roughly 5 or 6ft wide and 7 or so feet long, id HEAP that with firewood and shove the bed full as well, and the little 2.9 never gave a whimper.
Ive also hauled 27 bundles of ashphalt shingles IN THE BED of rusty #1, still ran 5th gear all the way home without complaint.
Ive drug cement porches, wedged broncos (long story), and all sorts of other things a ranger pry shouldnt of done. Never once did i ever feel the 2.9 didnt perform.
Ill give the 3.0 credit, like i said, they do ok. But a 2.9 is just better suited to truck duty and gives way more ass kick on an empty dead start.
Have you ever driven a good running 2.9?
