There are two vacuum hoses going into the top of the air box as well; one from the egr valve and one from the intake so it makes sense that it needs to be sealed, at least on a motor like mine with the egr setup.
May have been if you still had egr.There are two vacuum hoses going into the top of the air box as well; one from the egr valve and one from the intake so it makes sense that it needs to be sealed, at least on a motor like mine with the egr setup.
That's odd. And AFAIK, yes, it's critical that they get 4.98-5.02 or something like that as a reference voltage. I very easily could be wrong, though.I got a chance to check voltage and ohms on my ECT sensor, and I found out that my sensor is only getting 4.6 volts. My understanding is that the reference voltage should be 5. Is that a sufficient drop to make the ECU get bad readings all around? I'd imagine all my sensors are giving goofy readings, since the reference voltage for all sensors comes from one wire on the ECU.
Would it be worth it now to chase down a faulty wire in the harness?
Before buying a new one, may want to do some homework on repairing yours. If you can solder/desolder they're fairly easy to repair. Usually the capacitors just take a crap.I just chased the wire to the ECU. Absolutely no wiring issues. I believe the only thing I may be up against is a bad ECU. Any suggestions before I commit to buying a new one?
That would be good... Im a little time pressed, since this is my work truck/daily driver, and gas is getting prohibitively expensive here in CA. I ordered a new one. Will update with results when it's in.Before buying a new one, may want to do some homework on repairing yours. If you can solder/desolder they're fairly easy to repair. Usually the capacitors just take a crap.
