- Jan 28, 2017
- Leicester, NC
- Tire Size
- 205/60R15 & 225/60R15
I run a toploader 4-speed in my 2wd 302 truck. This truck is a daily driver. I currently use my stock 7.5 with 3.73 gears and it just feels like too much gear. I have an 8.8 with 3.08 gears and a 4.10 gear set I was going to have swapped out. Ten years ago I'd of went with the 4.10 or more but now I'm not so sure. Gas mileage is usually between 12-15 mpg depending on how I drive it, so usually about 12. Just cruising around the truck is pretty wound up and if I get on the interstate it's almost unbearable. I'm sure a taller tire would help but I have basically new 225/60-15s on the back. What are some of y'alls trans and gear combos? How do you like them?
