Axle spline count
Shadowrider6661
D RANGED
ASE Certified Tech
Off grid Northern Arizona.
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Is there anyway to determine if my axles are 28 or 31 spline without removing the axles ? The axle code is 96, and the tag ID is [S354F 3 73 8 8 7A16].
Assuming this is the factory axle in your 97 they are 28 spine.
The 28 spline tubes are smaller around, but I don't know the measurements off the top of my head.
The main tube on the 31 spline 8.8" axle uses 3.25" u-bolts.. I do know that much.
2.80" dia at the U-bolts = 28 spline
3.25" dia at the u-bolts = 31 spline.
An exception is 2010, 2011 disc-brake Ranger 8.8s, they have 3.25" tubes but are 28 spline (they also neck down to 3" at the pumpkin).
I thank you for responding to my thread. You're answer is greatly appreciated. Now I can order the parts necessary to get my truck back on the road !
My thanks and appreciation go out to everyone that responded to my question, it makes the rebuild aggravation free [at least for getting my parts].
