- Jan 6, 2002
- Pittsburgh
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 1.5"
- Tire Size
- 265/70-17
- My credo
- "220, 221, whatever it takes."
It's not heating but this is the sort of rain barrel setup I use. Usually you can find the blue barrels for cheap or free since companies just want to get rid of them. The barrel goes upside down, use a 4" hole saw and a 4" downspout adapter will pop right in. Seals tight, don't need a screen. A 1" hole at the top with 1" PVC for the overflow, runs into my drainage pipes. A 3/4" hole at the bottom (formerly the top) with a 3/4" boiler valve to hook your hose to, I use ball valves. I have one on each back corner of my house so I put two holes 180* apart to run a balance hose between them. The hose runs around the corner of my house to a $59 pump from Harbor Freight, then out of that to a splitter, one goes in the basement window to fill the washing machine and the other to the garden hose to wash our vehicles. Saves me $20 a month on my water bill in the warmer months. I take it down for the winter and put the regular downspouts back on.
https://www.diynetwork.com/how-to/outdoors/structures/how-to-create-a-rain-barrel
