- Mar 31, 2019
- FL
- 4.0 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- Just the right size to touch the ground.
2001 4.0
Two separate issues but figured I'd cover them both in one thread.
First, the oil pressure switch/gauge in the cluster is way off. It "sweeps" when you turn the ignition on but the needle sits at about 5:00 and completely off of the gauge markings. I haven't worried about it too much since I know it isn't giving a true oil pressure reading anyway, but figured if it's as simple as pulling the cluster and tweaking the needle, I'd go ahead and fix it. Anyone have this problem before?
Second, I replaced the t-stat housing due to the housing being spilt and leaking. I went ahead and rolled both both temp sensors while I was at it. I assume one of these sensors works the gauge and the other talks to the PCM. The problem is, the dash gauge reads normal temps and checking the hoses, housing and even the sensors themselves reads normal temps as well (~190° +-), but reading the temp with Forscan or TP through the PCM usually reads about 10°-20° higher and it's very erratic and changes too quickly for it to be an accurate reading. I figure it's a bad out of the box sensor, but which one? The harness looks ok so I figured I'd change the sensor again first. Am I right on the need for two sensors? Which one goes to the PCM?
