⭐Supporting Member
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
So I have found myself in a situation caused partly because I wasn't careful enough, and partly because someone else didn't follow my instructions.
I have two dogs on an invisible fence. When the fence was installed three years ago I told the installers to run the perimeter wire along the edge of the drive way and around a light pole in the front yard to avoid hitting the wires to the pole, or having to cross the side walk that cuts through the front yard to the house. They did not listen and ran it about 2 or 3 feet from the edge of the house. So two years ago when we put a garden in we rototilled the area, leaving about 1.5' from where I told them to run the wire, and hit it anyway because it wasn't where it was supposed to be. I pulled it out, moved it back, and repaired it and the fence continued working. The plan was to put in hollow cement block around the edge of the garden and runt he wire through them, so we didn't re-bury it. Last week I hit the exposed portion with the mower near where it went back under the ground, which cut it off, right at ground level, or possible pulled it out and the end is now buried. Either way I can't find it.
Now I know about the TV remote and AM radio signal tracer method, but I have only ever had any luck with that when I have been able to get the remote right against the wires, and within a foot or so of the break. By length of wire the closest section I know for sure where it is is almost 300 feet away. I don't have or know anyone who has a metal detector.
What I do have is this:
What I want to make is this:
I can read a diagram, but I am no electronics engineer.
Anyone have any ideas how to do this?
	 Welcome Visitor! Please take a few seconds and
