3.0 liter head swap
max sunrise
bc canada
Hi, i want to swap the heads off my 2005 ,3.0 liter for heads off of a 2000 3.0 liter.Will i have any problems ? Thanks
Welcome to TRS :)
No problems at all, it will work fine
Need new head bolts, can not use old ones
You may want to have the "new"/used heads tested at a machine shop and surfaced, may be install new valve guide seals(these come with head gasket full set), you need a valve spring compressor to install them
Can i use the head bolts off the 2000, 3.0 liter ?
New, not different, new. Those are torque to yield head bolts, reusing them once they have been put through the final torque sequence will cause head gasket failure in the short term.
Thanks so much for your help on this.Im retired and havent really worked on engines for many years. Ill keep you posted on my progress.Cheers
