Mike Tonon
Guest
I figure if I clean the crankcase out good and put in synthetic, maybe I can get away without changing it ever again? Just top it off of need be? And still get 5+ years out of the lawnmower.
I wouldnt even bother. Espicially if its an older engine. Itll start leaking/leaking worse if you change it.
Although ive found small engines to be pretty resiliant. My briggs on my push mower started clanking one day and realized in 3 years of ownership it still had break in oil in it.
Changed it, noise went away, and it still happily hacks the hell out of my yard.
Mine stopped running. I have no idea what's wrong with it. It acts like it is choked all the time, but the choke is moving fine.
I also cleaned the carb out really well and it just made it worse.
I'll look into that. Thanks.If it's a Briggs & Stratton L-Head, some models are known to have a carbon build up issue on the piston. I had that problem at one time. After I scrapped the carbon off and cleaned the head for good measure, the problem went away.
