- Sep 16, 2016
- Birdsboro,PA
- 2.9 V6
so i went to the salvage yard to get a transmission and found out once i got home that i pulled a fm132 instead of an m5od like i had wanted. but i think im just going to go ahead and swap the fm132 in since i already paid for it and dont feel like finding another once since it was already hard enough to find a 2.9 2wd ranger. most that i found in my area were either 4x4 or had a 2.3. i did all sorts of research to put the m5od in and now that i have the fm132 im trying to find out a couple of things. first is the transmission the same length and output spline the same as the a4ld currently in my 1987 2.9 2wd?
second do i still need that floor plate cover to fill the shifter hole? third, is there a separate throw-out bearing thats not integrated into the slave cylinder? and lastly, can someone give me some sort of detailed instructions on removing a clutch pedal assembly in a first gen? thanks, I tried doing some research but seems like there isnt much info on the fm132
