Brake fluid in power steering HELP !
Zipper
Sarasota FL
:icon_confused:
As an old geezer who really should know better I've done the unbelievable, Topping up the power steering I find I've picked up the wrong bottle from the shelf and poured in Dot3 brake fluid....
I've pumped out what I can reach but what now?
Do I simply pop the line, drain all the mixed fluid and top it up, or will it need to be flushed first ?
Any input welcome
:icon_confused:
Any input welcome
Seems about right. Short of having a bucket full of Mercon V in one bucket with the intake hose and the output hose in the other, Not sure you could flush the system out any better.
I wouldn't worry about it. Both are hydraulic fluid. Brake fluid can be used in some power steering systems, and I believe some even call for it. The reverse is NOT true though. Power steering fluid can't be used in the brake system because brake fluid requires a higher boiling point.
Just drain or suck out what you can get, and fill it back up with fresh power steering fluid.
GB :)
Yeah, brake fluid in the PS is not nearly the disaster that PS fluid/ATF in the brake system is.
In fact it was an old timer's trick to pour a little DOT3 into the trans if it was slipping.
Disaster averted !!
Sincere thanks to all who proffered advice.
A hand pump from Harbor Freight did the trick (altho' of course I dropped a tiny part into the engine compartment and had to make a temp version with tape!)
Fresh (correct) fluid and she's right as rain!
:yahoo::yahoo::yahoo:
