Still can't get heat!
We have a 1999 ford ranger 3.0L engine
2 wheel drive manual transmission.
We can't seem to get heat.
Here are the steps I've taken so far!
We have had no heat since last winter. It just stopped one day...
I have replaced the thermostat
I have replaced the water pump
I have replaced the heater control valve and it is in the open position
I have flushed the whole system
I have flushed the heater core separately using a garden hose and there was decent flow.
I have tested the blend door and it works. I was able to swivel the door with my hand when the actuator was removed.
I have tested blend door actuator and i can c it moving and took it apart and the gears are not stripped
Heater control is working as it moves the actuator when the switch is turned
The rop rad hose gets nice and hot i can hardly touch it. What the heck is the problem?? I have run out of ideas???????
