Uncle Gump
Boomers gotta Boom
⭐Supporting Member
TRS 25th Anniversary
- Sep 17, 2018
- Ottawa IL
- State - Country
- IL - USA
- Vehicle
- Ford Bronco II
- Drive
- 4WD
- 2.9 V6
- My credo
- Lead follow or get out of my way
Do the brake shoes return to the pin when you lightly press & release?
Denise... It's one thing to look at that statically. It's a totally different thing dynamically. If the return spring are weak and/or damaged... they may very well have enough effort to return the shoes to the anchor pin with the drum off during a static state. When in a dynamic environment... brakes applied and self energized... generating heat. Weak and or damaged return springs might not have enough effort to pull the shoe back to the pin.
You also probably noted that the park brake strut was indeed removed in the pictures... so it eliminates anything park brake.
