- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
So I am clearly not happy with an automatic transmission, not something new.
I am bringing the 64 Mustang project to the home stretch. I got the engine running a few weeks ago, filled the tranny fluid and started putting the trans through it's paces with the rear on jack stands. It went forward just fine, but wouldn't engage reverse.
I got busy with other stuff, left it sit for a few weeks, came back, threw a pressure gauge on it, put it in R, and had the specified 150-ish PSI on my gauge, cool valve body is working. Look at the rear wheels, and they are spinning backwards. I figure something in the valve body was hung up from sitting dry for a while and sitting in ATF freed it.
This afternoon I finally got the car to the point of moving under it's own power. I put it down, fired it up, and pulled it outside so I could clean up and scrub the floor. Got all that done about 9PM, go hop in, fire it up, the dirty whore won't go into reverse.
It felt like it engaged for a second or so, but I had the parking brake set so it didn't go anywhere.
My shift detents are not well defined, in that I can't easily feel them through the shifter, but R should be the easiest to find. I did not throw the pressure gauge back on it tonight since it was dark out, I hadn't eaten in over 12 hours, and I didn't feel too good after pushing the car uphill into the garage. Also my floor was still wet.
Does anyone have any ideas on why I seem to have intermittent reverse?
EDIT: Screw this car. I am going fishing tomorrow.
