2000 F150 V6, what T-case?
pjtoledo
⭐Supporting Member
Toledo Ohio
found a manual T-case in a 2000 F150 V6 auto tranny. any chance it's a BW1354? or will bolt to a Ranger M5OD?
will the shifter fit a BW1354? can it be easily adapted?
1FTZF1828YNA50824 if that helps.
couldn't get under it to look, probably too big.
Should be BW4406 and completely incompatible with a RBV transmission.
Not to mention the incompatibility with the frame.
Actually rather popular for V8 swaps in 98+ trucks. IIRC fastpakr has one in his truck.
I thought there was a width issue. Too many transfer cases.
are 4406's worth grabbing for future use/resale?
no idea what they want for it yet.
I have a manual shift 4406 in my 98 5.0 Ranger.
If it's a manual shift 4406 and includes the linkage, definitely see what they want for it.
Adsm - it's a big case, but it definitely fits. One of the top bolts is a pain to get to on a Ranger install, but otherwise it's all good. With a one inch body lift it fits like it was made to be there.
fit good. work great. way better then a 208.
it was indeed a 4406,,,,44-06-000-021 to be exact. XL34-7A195-AC
that t-case, the entire shifter assembly/boot/stick is now at my place. got the front drive shaft and a baggie of bolts too.
