I'm assuming because I was a dummy and didn't pinch the brake line that there's air in my brakes. How do I fix this? Bleedbthe brakes? I've never done that- easy enough or is it a complicated task?
Thanks!!
Thanks!!
Uhoh, you did not pre fill the new caliper with fluid? you should be able to open the bleeder with a little tube connected into a container and add fluid at the master cylinder until it runs without bubbles, this actually works I've seen it done many times.
I've learned how but rather not, use a little gadget called A Mighty Vac they're pretty cheap and you can bleed the whole truck by yourself starting at the right rear wheel.
Don't let the master cylinder run empty.
If the fluid doesn't run you may have a bad brake hose too,
Don't know, but usually before you change calipers or front brake lines you go on the Assumption there is no air in there.Wellllllllll shoot no I didn't know I had to put fluid in the caliper. Too late to take it off and do that? Or do I need to do the full bleed at this point?
Ive never filled them with fluid. Just top the master cyl off, have someone pump the brakes, HOLD THEM, while you turn the bleeder screw (tiny little screw, kinda looks like a grease zerk). Tighten screw, release brake pedal, repeat. Do this untill the pedal gets good and hard![]()
Experience is a great teacher, but I am thinking you should have another teacher for brakes until you get some more experience. But bear in mind this is coming from someone who almost wrecked his truck after the first time I replaced the front brakes, because I didn't know you need to pump them up to get the calipers pushed out and the pads in contact with the rotor the first time.
Did you fix the fluid leak on the back of the truck?
