Hi everyone, I recently noticed that my driveshaft going into the differential has a lot of play. It doesn't seem like there's any excessive backlash between the pinion and ring gear but the spider gears and the center pin all do a lot of moving around. I found a video that shows the exact same symptoms as my truck has, I'll put the link below. Just wondering if this is normal or if I need to do new spider gears and center pin. Anyway take a look at the video and tell me what you think if you have a couple minutes. If not no worries.
Thanks,
Alex
It's a 97 2.3 2 wheel drive 5 Speed 7.5 open diff 4.10 gears with 80,000 miles
https://youtu.be/n96vqaNs--M
Thanks,
Alex
