Flatbeds.................
Truckedup
5+ Year Member
Marion NY
I pulled the bedliner out of my 09 4x4 Sport to find the bed is rusted badly...Big holes in the floor and wheel wells, the three inner cross rails have turned to dust. I pulled off the bed.....The frame cross member behind the cab was rotted but I welded in new metal..The frame rails are ok....I should have looked closer when I bought it....But the cab is still solid....
Finding a decent bed around here is near impossible....I have made flatbeds for other trucks in the past using oak boards instead of pressure treated that always looks like a picnic bench...But wood always looks like wood..
I see Aluma sells a nice looking bed in the perfect size for a Ranger, about 1500-1700 bucks...200 pounds....
Anyone have experience with these aluminum flatbeds?
It's... your money..... your truck ....your decision.... your ..... And ..... All.... those dots!
If you can't find a Bed locally and means driving there is actually a discussion on how to carry one back upside down on the bed of the existing truck.... .... .... ....
I've seen a lot of steel flatbeds on rangers around here. they seem pretty nice. Main thing would be to make sure your lights will work and your fuel filler neck. Everything else is just hardware to get it mounted securely. If you're truck is as rusty as it sounds I would make sure you are getting it mounted to the frame really good. I had an old ranger and it was super rusted. I was surprised the bed stayed on as good as it did. Are you able to contact the manufacture and see if it fits directly to your ranger?
The bed isn't supposed to be wood, just the decking. I like steel because you can weld anything you want to it, anywhere you need it. I like a wood deck because it is more quiet, softer and things aren't as prone to sliding. It's also easy and cheap to replace and doesn't rust underneath. But you can use diamond plate instead of wood to deck a truck bed--the bed itself is steel.
Aluminum is neat stuff, just not as versatile or as easy to modify or repair.
If it is a 6' bed I swear they about grow on trees. Anything 93-11 interchanges.
If it is a 7' bed... lets just say they don't grow on trees and I feel your pain.
Speaking from experence, unless your hauling pallets of stuff or hay, flatbeds are kind of a PITA.
It's a 6 foot...If they grow on trees, pick one and send it to me :D. The local dismantle yards have nothing good...Nothing on CL within reasonable driving distance..
A flatbed isn't by first choice.....but it might be the only choice..
My Dad loved flatbeds...especially home shopped flatbeds of steel frame and wooden bed.
The last one he built was a short bed on a short wheel base Ford F250. You could get that truck into all kids of tight spaces.
Not as tight as a compact Ranger though.
www.car-part.com
i wish i would have built my flatbed the week before i bought my truck and installed it the day i got it.
i cant describe how much better it is for the stupid shit i do.
your not limited by choice here...no reason to flatbed one of these things if that is not your needs or style.
for sure you can, "all in".... including fuel costs to go get it.... purchase a good bed for 7-800 bux.
and if you are patient, get one with good matching paint.
15-1700 bux with no bedsides and tailgate is pretty stout money. not that a nice aluminum unit like that is not worth it.
is the truck worth that much? would a flat bed suit your needs?
I guess the bottom line is it's my wife's truck and she wants a flatbed....My truck is an 03 Rustarado...:D
Here in NY and most likely in Pa and Ohio, any bed in a dismantler's yard is is likely to have a rusted floor and cross rails..Of course there's always the chance it's not rusty...When I call they say the bottom is good, they are busy and don't want to have to take time get better photos especially if the bed is still on the frame...I'm retired ,but still driving, 3-5 hours one way on a guy's word is a bit risky..
I'll make a few more calls tomorrow based on the leads in the link above that look promising...
I spent the last few days , hammering, scrapping and wire brushing the rust from the frame rails. As mentioned I repaired the cross members..I painted the frame behind the cab with a Chassis Saver..Then sprayed the entire frame and under side of the cab with Fluid Film...
I really got screwed on this truck purchase and need to make the best of it. It's got new tires, runs and drives excellent, has a good looking cab and front clip...If 350 bucks and several hours use on the table saw will make it better, that is a way out.....My retired friends are playing golf and riding around in new vehicles....They are missing out on all this fun...
I know its a far drive but there's a recycling place here in Mansfield, Ohio called Milliron and they have TONS of vehicles in their yard. They are one of the biggest in Ohio. You can search their site and see if they have a truck with the same year/model. They don't normally have pictures but they keep their lot pretty clean and organized. You might be able to call them and have someone get pictures for you. They are not like your average scrap yard. Might be worth a trip. I know Ohio is a rust belt state but their are a few gems out their that are 90 percent rust free. They do a pick-n-pull too so you can get a lot of good parts for cheap.
Somehow a video for a Ranger Alumabed flatbed popped up in my youtube feed, by Southwest Trailers.
Found it on their website, over $7,000. You could probably buy a welder for that.
Then get him a nice welding machine a material to make to make a flatbed too.
Aluma flatbed I showed in a photo earlier in this thread is $1500-1800 brand new at several places. ,not 7 grand. .I have a TIG welder ......I think material might cost 600-800 bucks?
By sheer luck I found a bed 120 miles from me on the NY PA border. It's a 2005 from Texas..Zero rust,the bottom looks like new a few slight dings..Had to pay a grand but it's way better than any beds I saw up to this one...
Taking a break at a burger joint before heading home...
