- Apr 30, 2008
- Yamhill, Oregon
Even if your lights don't dim a capacitor "reacts MUCH faster than your battery or alternator can.
It's about the ability to DUMP energy in microseconds.
Even bigger cables and multiple batteries won't do what a capacitor will
They might not help, but certainly won't hurt.... except your wallet if you overpay.
A flux capacitor, 88mph, hmm.... is just might work!
88? that doesnt sound right...i thought it was like 83 or 86 or something....its been a while.
i vote that caps are band-aids. they may dump energy faster than your battery, but its nothing that is going to improve a well set-up and properly fed "average joe" system.
you my friend must really like dumping money into alternators, like AllanD said, when you have an event that lasts milliseconds you need all the juice you can get, and when you constantly have to draw that extra juice from your alternator or battery it will prematurely wear those components out. the "cap" depending on size, stores between 18 and 20 volts, which is isolated from the rest of the vehicles voltage needs so that when you listen to music with alot of bass it gives your amp a little somethin-somethin to draw off of without puting undo strain on your charging system.88? that doesnt sound right...i thought it was like 83 or 86 or something....its been a while.
the discussion wasn't about "average joe" audio systems
so your your "fact (and opinion) is irrelevant and uncoordinated.
There is nothing "Band-aid" about it, I've had a vehicle with FOUR batteries
(two under the hood, wo larger "aux" batteries in the back and a Diesel engine with a 150amp alternator and frankly the capacitor still made a difference.... but in my case it wasn't an audio system, but rather a fairly powerful radio transmitter.
What everyone here who talks down at adding a capacitor is simply
ignorant (lacking knowledge) of the facts.
Batteries store energy chemically they cannot react to load
events lasting milliseconds.
Alternators have voltage regulators that also can't react fast,
(particularly when the alternator is being turned by an engine
at idle speed.
a capacitor can in some cases can react in MICROseconds
MILLIONTHS of a second and they can dump ALL their energy
in one big spark a battery cannot come close to that
Basically it smooths out the dips and absorbs the spikes.
In a way it kinda acts like a shock absorber between the electrical system and what ever device you are running off it.
MOST things don't notice those spikes and dips.
Audio systems and two-way radios do.
AD
