Nice seein you making some headway on the truck yourself there brotha . Thanks guys .
So lately I've been doin a lot of reading on trying to add a lil more angle to the ranger . But with me having a beam setup, There's not much out there for info on rangers doing what I do . So I ventured off into Google land and looked at other fords with boxs and see what splines and lengths they have . Well ford either has a 32 spline or a 36 spline box in most the truck chassis . I found a 2000 f250 pitman arm that is 1..25 inches longer in a 32 spline I'm going to test . Should get a few more degrees of steering angle for it and maybe a faster turning response
Sent from my iphone while gettin sidewayz!!!
Speedway motors has universal pitman arms that will work. Ill have to look up the part number if your interested. But the Ford steering box is a tapered/splined shaft not just splined. I did one when i swapped to a manual box. but it will be a different spline manual or power. im not sure the exact spline for the power steering box, you could give them a call and they could point you in the right direction.
Z
