Bretsk2500
- Mar 25, 2017
Hi,
I'm new to the forum.. I recently picked up a '98 extended cab stepside (3.0) with an amazing body and frame for a song to replace my '02 reg cab short box (2.3) with a hopelessly rotted frame. anywho...
I'm not super familiar with the quirks of the 3.0, I know it needs heads or head gasket (which are on their way) due to combustion gasses in the coolant... The other issue when I start it... it will high idle just fine for about 30 secs then load up and die... it is like something is making the IAC just completely close, making it go waaay rich and stall... crank it again... runs just fine for about 30 secs, loads up and does the same thing.
Not trying to re-invent the wheel, on the 3.0, what are the most likelies? definitely acts like it isn't getting the right A/F ratio.
The only other 3.0 I deal with is an '04 Ranger shop truck at work.... and it's never required anything other than basic maintenance..
Also is the DIS for the 3.0 as maddenly weak as the DIS on the 2.3?
-Bret
-Bret
