- Mar 4, 2017
I'm working on my Grandpa's 2003 Ranger with a 3.0. Long story short, I seem to have a misfire on cylinder 5 and 6 at all RPMs. Compression, Spark, and Fuel appear to be good. I'm stumped.
Background info:
Grandpa was driving the truck when it overheated on him enough to lock up the engine. Found out the radiator had a massive leak. We got water in it asap and I was able to get it restarted (but running poorly) within 30 minutes. Then got it to my shop a mile down the road.
Several days later I started looking into it. Found very poor compression on 3 cylinders. Ended up pulling the heads to find both heads cracked. Cylinder bores and everything else looked fine. So I got a set of reman heads from NAPA and put on.
Fired it up a couple days ago and it started right up but ran very poorly. I thought I had the spark plug wire order wrong or something, but checked it 3 times and everything is right.
Troubleshooting I've done:
Tested compression on all cylinders and all cylinders are 175-180. Checked spark and had very weak/intermittent spark on several cylinders. Replaced coil and that made everything much better, but still missing. retested spark and now have great spark at all plugs (plugs are brand new as well).
Pulled plug wires at the plugs while idling and think i have it isolated to cylinder 5 and 6 (no change when pulling wires). Pulled upper intake and swapped injector 6 with injector 4 (thinking 4 was working fine). No change in symptoms (cylinder 4 still firing fine). Fuel pressure is steady at 63 when running and leaks back to 50's when off.
There is also a tapping noise coming from the drivers side valve cover. I pulled the valve cover back off and inspected the valve train. a couple rockers have some side to side slop but don't notice any up and down. push rods and lifters all appear fine. Turn over engine by hand and all the valves seem to do what they are supposed to and have the appropriate travel.
Check Engine light is off through the whole process and there are no pending codes.
I'm suspicious I have a bad upstream o2 sensor on bank 2, but don't see how that would cause a misfire on cylinder 5 and 6, while cylinder 4 is fine.
Sorry for writing a book, but I'm stumped and wanted to give as much information as possible. Anything else to check?
Background info:
