- Jul 23, 2010
- Age
- 63
- Pollock Pines Ca
"Easy steps" are fine, what are you trying to test first?
A DVOM is a "Digital Volt/Ohm Meter", the same as a multimeter.
I been doing the wire checking I can't find anything wrong thus far. I fired it up sounds great no missing or popping or running rough. I ran it up to 2500rpm's for 10 mins than let it idle at 800rpm's as I checked and moved wires it ran smooth no stumble. This is the part I don't get now if I hit the freeway going 65mph and start up the 6 mile grade before I get to the top its starts its missing/popping issue. We all know that same song and dance with this on going issue. I am not real sure what I should be testing first?
I did notice the under hood light was dim when running at idle it would go bright when at 2500 than dim again off and on. I did check the volts as it did this it stayed around 14.35 the alternator sounds bad at times like a worn bearing or bushing clunking noise. The alternator light does come on and off a lot I don't know why when the voltage is ok when testing with light on and off and hood light dim and bright
I was also thinking when it starts its misfire issue pull over disconnect the battery for 5 min than re-connect it. Would this reset the computer? maybe pin it down closer to a computer issue if the misfire goes away for bit?
