I'd like to swap for an older model Ford dash. Anyone have an idea what older model Ford trucks/cars would be compatible?
Yes...custom.
I've seen some pretty nice home made ones over the years...wood...metal...custom gauges and all that...but I'd have to ask...why older dash?
Except for the terrible defrost on the first generation dash I actually liked it. I went with a 96 dash in the 88 cab because of the better defrost and the fact that I didn't want to try to figure out how to make everything work with the FI wiring I upgraded to...
But going older means you'd pretty much have to measure everything...and the only options for a truck dash would be the older Courier...or something not Ford...but the Ranger was, I believe, one of the first mini trucks by Ford so the pickings will be slim.
EB's and old trucks (like 40-50's) may be similar inside for dimensions.
Once I ditched the plugged evap core mine defrosted a lot better, still have to switch from defrost to panel (with the outer vents aimed and the side windows) though.
