- May 16, 2016
- Portland, OR
- My credo
- When life gives you lemons, just shut up and eat your lemons.
All,
First time poster, second guessing my choice to buy a used '95 B3000 that needs to make a trip x-country next week. I'll start by saying that I've been reading as much as I can on this topic, enough to be dangerous, but not enough to know what I'm actually talking about.
Here's the primary problem: my V6 3.0L B3000 is overheating to dangerous levels while at idle, unless you rev the engine. Here are the symptoms:
1. Engine runs nice and cool at speeds above about 30 mph.
2. At idle or at slow speeds, coolant gauge quickly (<2 min) will peg out at the max.
3. While at idle, if you put truck in neutral and rev to around 3K, coolant temp gauge will quickly drop back down to middle or below
4. Heat just won't come on if you start up and drive while it's cold out, even for 30 minutes at 40 MPH. But if you let it idle for a while, it will kick in nice and warm.
Here are some additional things that may be related:
1. Transmission fluid seems GROSSLY overfilled. As in, 3 times higher than the high fill mark. I tested this while hot and idling, following proper method. It doesn't seem foamy, but I don't know what it's supposed to look like otherwise.
2. Small puff of white smoke when I start up the truck most of the time
3. Coolant reservoir is full, almost to the neck, and the radiator seems not at all full. Almost as if it's not flowing back into the radiator. Have not yet tested this from a cold start until hot and bubbling, to see how much the fluid should expand, or how it flows in. This is just an observation while cold.
4. Previous owner supposedly replaced the thermostat. I'm not convinced they did this at all, or that they did it properly.
5. I can spin the fan with mild resistance after it's been freshly driven. It is not free spinning. It is also not stuck. And I jammed some newspaper in while running and wasn't able to stop the fan - it seems to be on there pretty good.
6. Engine definitely leaks oil, possibly some other fluids.
7. Pulled a spark plug and it was totally burnt out, possible oil on threads but could have been my PB blaster. Will check more tonight.
8. Engine oil seems fine, not milky, not overfilled.
I have not yet checked compression or done a coolant flush. Will do compression check tonight, but fluid seems bright blue and very clean. Radiator cap seems clean and new, wouldn't expect it to be that. Not sure what kind of job was done on the thermostat, but I'll be checking it when I do a coolant flush in a couple of days.
Here are my questions:
I desperately need help, would like to eliminate the things this isn't and make sure the vehicle doesn't explode on me and destroy the engine during my 3,000 mile trip next week.
- Is there a chance this is the fan clutch? I don't know how loose it should be when cool, or how to test that it's fully engaging / disengaging.
- With all of these symptoms, some of which could be unrelated, could this just be air in the coolant system and it needs a proper bump?
- How likely is it that this is the water pump impeller going bad? There's no wobble in the bearings, at least.
- How likely is it that this is a blown head gasket? It sounds like this would mess up the vacuum line, force coolant out of the radiator and into the reservoir. But it doesn't explain why the system cools down so quickly when I rev the engine, which sounds more like a water pump issue.
- What else could this be? Bad vacuum lines? Clogged coolant line somewhere? Something else?
- What possible causes are there for why the coolant reservoir is so full and the radiator is so low?
