- Sep 27, 2014
So I'm not exactly sure if my issue is the WOT relay or TPS because I don't really know how the WOT relay is supposed to work...
Anyways, I have a 97 ford ranger 2.3. With the AC on, it is to my knowledge that the WOT relay will open when you give the truck a certain amount of throttle for climbing hills, passing, etc. The issue I am having is that I will floor it with the AC on and the compressor continues to cycle. I've even had it where I was going downhill and it wouldn't cycle, but when I would start to go back up the hill, the compressor would kick in like it's reading in reverse... Seems to me like it would be WOT relay because I do have an issue where the AC clutch will engage with the heat on, not on defrost... but I also think it could be the TPS since it has to read throttle position..
Any suggestions?
Any suggestions?
