- Aug 9, 2015
- San Antonio, TX
- My credo
- "When you need it, and don't have it, you sing a whole 'nother tune." -Burt Gummer
DIY Filler Hose for 1998 Extended Cab w/ 17 Gal Tank
Howdy folks! Got something in mind here and I wanted to pick your brains for a minute, if you don't mind.
It seems that Ford has decided to stop making the filler neck-and-hose assembly for my truck - the 1998 Mazda B2500 SE Cab Plus. Which is really fraggin' annoying because I've discovered that non-OEM versions of this particular assembly are stupidly susceptible to dry rot. (If you ask me, two years is not an acceptable life span for this component!)
Seeing as my problem is with the hose and not the filler neck itself, I've tried to find a replacement online without any success.
But then I had an idea...
The filler hose has to bend in two spots to fit properly without kinking - a ninety-degree angle at the top of the fuel tank an a forty-five degree angle where it comes up from under the bed.
And then I notice that many 'universal' filler hoses available are 45-degree and 90-degree angle hoses.
Naturally, I realize: "What's stopping me from joining two of these hoses together!?"
Of course, there's the question of how to do it, but that's pretty easy. I figure a piece of stainless steel pipe or fuel-safe plastic and some extra hose clamps will do the job just fine. As an added benefit, this method also provides a point where I can twist the assembly to a better fit without kinking the whole mess.
So, here's where I'm lacking: knowledge of materials.
Specifically, I need to know what company makes the most reliable hose materials - if possible, I'd very much like to not have to make this replacement ever again!!!
Also, for the joining-splice between the two hoses: what would the best material be?
Finally, as a bonus: Does anyone know what diameter of the hose should be? I'd go find out myself, but pulling the bed off my truck is a bit of a pain in the ass when I'm doing it myself. (How I wish I had a fully equipped machine shop.
If this thread gets enough interest, I may even write up a tech article with pictures and everything - just to help others out, because I've noticed this seems to be a common issue on Rangers and B-Series trucks.
)If this thread gets enough interest, I may even write up a tech article with pictures and everything - just to help others out, because I've noticed this seems to be a common issue on Rangers and B-Series trucks.
