Moser Engineering has a listing for 31 spline axle shafts with the small 1.4 bearing. lengths are 27-1/4 and 30-1/8.
part # A31-93RANG, lists it for 93-97 rangers.
that sounds like you could take a regular 28 spline 8.8 axle unit and switch it over to 31 splines with these shafts and a new 31 carrier. though it would still have the small bearing & shaft diameter. this may open up some more choices for lockers & LSDs.
got a question about the 2002 level II 31 spline unit, what size bearings does it have? 1.4 or 1.6xx? EDIT, just reviewed the tech listings, it shows the big bearings for FX4 II, but has no 31 spline listings for 93-97
