- Feb 16, 2016
I think the oil pump sleeve was a little longer on the '98, but it should still slide in and work fine.
You do need to time these.
If there is one near by you could have an auto parts store pull out both models and compare them side by side, but I don't think there is much of a different mechanically.
You also have to change the Fuel rail and injectors, '98 had 65psi no return line, '94 35psi with return line
