Bench seat swap
gottaba5spd
10+ Year Member
Hey guys, probably a noobish question but I'm looking at a b2300 single cab to buy and my only issue with the truck is that it has a bench seat, and I want to know if I can swap in the 60/40 seats. Thanks guys.
Yes, just get the seats and tracks out of a similar year truck with a standard cab and go.
You will have to drill holes in floor for the inner seat mounts, my '85 was dimpled where they needed to be.
Did it go all the way thru the floor? Also did you tap threads in the hole or did you run a bolt with a nut and lock washer (if the hole went thru the floor)?
