- Apr 7, 2015
- Clarksburg, WV
I've had my truck to three different stations, at all three the gas backs up into the neck after I get maybe half a gallon in and shuts off the pump, even when I'm just barely squeezing the trigger. It takes 10-15 minutes just to get 3 or 4 gallons in the tank.
Is there some kind of a fix for this? I feel like the majority of what I've seen regarding this issue is "Oh, Rangers are just like that." I can't be driving this thing on a regular basis and have it be this hard to get gas into. I also heard mention of the charcoal canister being plugged, I pulled it off the other night but had no clue how to check anything with it so I just put it back on.
I had a similar problem on my old diesel F250 that was caused by the rollover valve on top of the tank. The fix was to gut the valve and run an external vent to the filler neck much like how these are set up OEM, and after that fix I could fill the truck at the high flow semi filler stations.
Does enlarging the vent tube make it any better?
