- Mar 24, 2013
- Age
- 81
- Renton, WA
- 02 2X4; 08 FX4
02 Ranger 4.0, Auto, 2wd, 93K.
Back ground. Truck as set for about a week. Put key in and went to run. Let the key set there for about 5 seconds while I check instrument lights. Then turned the key to start and engine started on first hit like normal. And then...
The engine went to 1500 rpm as normal and then immediately dropped to 300 rpm and then died. About two weeks ago, it did something similar. Started on first hit, went to 1500, dropped to about 500; but, that time it immediately went back to 1500 rpm. This time it died. Tried to restart and it acted like it was doing a WOT thing. Tried three times and then quit trying. I had to pickup GD so used another vehicle.
When I got back (about 15 minutes), I did the prime the pump thing. Key off, key on for three seconds, key off. Repeat three times. Fourth time went from off, to run, to start. It started normally on first hit, went to 1500 rpm, held there for some seconds and dropped to 1100 rpm. Everything completely normal. Restarted three times and it was normal each time.
So I need ideas on what us hanging up, sticking or not doing its thing??? My Granddaughter drives this truck a lot and I don't want to/can't leave a 17 year old girl stranded someplace knowing there is something weird going on.
Thanks, Ed
Thanks, Ed
