- Dec 5, 2012
- Central FL
- My credo
- The answer is always NO, if you don't ask!
You are absolutely correct. I used one inch spacers. You could use the ford racing hub in the T-bird IRS to keep the 4.5 bolt circle but would still need the greater backspace for the greater width. I found it simpler and more economical to use the adapters on the front.
