Camber issue
ZBradley
10+ Year Member
So I just bought my first Ford Ranger. It is a 1993 Ranger Splash with the 4.0 automatic with push button 4x4. It has some sort of lift on it as shown in pictures which I was told is the cause of my camber issue, is there a way to fix this WITHOUT removing the lift?
Camber issue
Camber issue
Camber issue
Any ideas?
do you know what camber bushings are currently in it?
does it have radius arm drops?
3 deg bushings and 150 arms with relocated crossmember usually can solve that and increase wheel travel. where are you located?
