So I just bought my first Ford Ranger. It is a 1993 Ranger Splash with the 4.0 automatic with push button 4x4. It has some sort of lift on it as shown in pictures which I was told is the cause of my camber issue, is there a way to fix this WITHOUT removing the lift?
Patience Padawan...I think I have seen some things on camber and lift on here.. you might check out the suspension subforums.. might be as simple as a new camber kit for a lifted truck. Check out the tech library (top of the page) as well. Until then have a cold one and sit back and shoot the breeze with us
Go to Napa and get some new alignment bushings, I think their biggest is 4 or 4.5* which should take care of most of that issue, you could attempt a DIY alignment with a tape measure, I think there's something on it in the tech library
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
