When I bought the truck, the temp gauge was reading quite cold (but not sitting on cold) and the heat didn't work. I drained the coolant and it was very brown. Installed a new thermostat, refilled the coolant, and burped the system.
Now the heat is working excellent, but the temp gauge says full cold (doesn't move at all that I can tell). Put a ground on the temp gauge wire and the gauge went to hot, so that's good. Installed a new coolant temp sender, but the temp gauge still doesn't move from cold.
Ideas?
Oh, also the fan that was on it was the OE plastic garbage so I put a new aluminum fan in it. That thing moves a heck of a lot of air. Wondering, is it possible that my fan clutch is bad and the fan is spinning full bore all the time and overcooling the engine?
Ideas?
