Chris_North
- Jun 13, 2013
Short and sweet:
Has anyone ever used the trans heat exchanger in the radiator to cool engine oil? I didn't search these forums admittedly but I did some google searching and the best I could come up with is 60% of people saying it's a bad idea the rad exchanger isn't meant for those pressures or volumes and 30% of people disagreeing and saying it's fine. But nobody actually seems to have done it. I've read that there are some models of cars/trucks that have an oil cooler setup through the radiator built in from the factory, but that's I'm sure something they engineered for that purpose, not repurposed something for something else.
Long version:
It occurred to me today that the trans fluid coming from the transmission going to the radiator cooler rarely makes it above 190F in my truck (and not too often does it see that unless I'm hauling or it's hot out). The engine coolant operates between what 180F and 215F? With auxiliary coolers, isn't it counterproductive running the 170F fluid to be "cooled" by 200F fluid? TBH I don't know exactly what temps the coolant runs at but I do know my trans temps.
Over the weekend I installed a new radiator and while I was at it I decided to give one of those electric radiator fans a whirl (haha, unintentional pun). Today was my first road test with my 50 mile highway commute and 45 mile back road trip home (to avoid traffic). On the highway I noticed no difference with the e-fan over the belt one with regards to temp, but the oil pressures (which like a lot of rangers is normally low already) were running maybe 5 PSI lower than normal. I have no real way to check but my engine block seemed a little hotter than normal when I finally stopped. The hilly stop and start backroads is where I noticed the change. Oil pressure was still a good 5 PSI lower than usual, but trans temps went higher faster and stayed there longer. I run an additional cooler to the stock aux one and usually neither one gets very warm, but today when I finally got home they were both hot to the touch. Odd thing is, the in-dash coolant gauge never got above where it would be with e-fan, so I'm thinking it's down to the electric fan only moving enough air to keep the coolant at temp and only coming on as needed and not constantly moving air through the aux trans coolers and around the engine.
So basically in order to keep my trans happy with the e-fan I think I'm going to have to install a better cooler, which is okay because i was planning on it anyway. But like I said I got to thinking today with the coolant temp ideally running hotter than the trans temp, why even run it through the rad's heat exchanger at all? If that exchanger is freed up and my engine oil is (or so I assume) running hotter than ideal why not utilize the exchanger for engine oil cooling? Anyone find any flaws with my reasoning?
Long version:
