Ran out of fuel, won't fire up.
SAR STX
10+ Year Member
Napa, CA
I am fairly certain it ran out of fuel. I had one more errand to run before the gas station, and when I came out it wouldn't start. It was very very low.
AAA came with their five gallons and it wouldn't start so the guy towed it home for me.
I've primed the pump 20 times. The valve on the fuel rail gives a good squirt when tested. I inspected the fuel lines at the FPR and the fuel line is normal, though the return seems dry.
I unhooked the battery hoping to reset the computer.
Still turns over like normal, just won't catch.
I haven't checked the inertia switch, maybe it got tripped when the truck was towed?
Suggestions? I'd really like to drive tomorrow.
Well, if you have a good quirt at the test port and it sounds like you can hear the pumps prime I really doubt you tripped the inertia switch.
Have you considered causes other than lack of fuel? Like lack of spark.
only now that it still won't start. i'd like to test the TFI if I knew where to find it (hope its not back with the distributor).
About two months ago I was in the same situation. Truck wouldn't start and I found a leaking rubber fuel hose in the engine compartment. (the steel braided jacket was rubbed through and chewed up the line effectively running the engine out of gas) I replaced the hoses and couldn't get the truck to start. I think I remember I got it going by priming the pump 50 times or more our of frustration. I don't know how much of a difference 50 primes vs 6 primes has.
A complication with the fuel hose was trapped air. will the valve on the fuel rail bleed out air bubbles? the truck is currently parked down hill.
I do have a manual timing adjustment thanks to the MSD ignition. Would reducing or increasing the timing help it start?
Thanks for trying to help me.
Also: after the aaa guy filled me up the truck caught for about three seconds and slowly stalled out.
Is there a good test for the pressure regulator? I just checked the vacuum for gas.
Bro this is no B.S... Prime! Prime! Prime! It takes me anywhere from 10 min up to 25 min to prime my truck. Keep in mind I don't know what type of fuel system setup you have in your truck but I have dual gas tanks, two internal pumps, one inline HP pump, three fuel filters, one fuel reservoir, and a fuel log to prime(stock from ford, except the fuel log). It will take you a pretty long time to get it to prime no matter what setup you have. check the link below for more on priming... third post down=
www.therangerstation.com/forums/showthread.php?t=142668
Even though it just happened because of the gas, I'd still check the spark. If it's good every where, pull the coil wire and see if the plugs get wet with gas. If they do, the gas has made it to the cylinders and it'll basically clear that as the issue.
I've just replaced the fuel filter, going to prime for 30 minutes or until bat dies. I'll report back..
did a nice 35 minutes of 2-5 second priming. no start but the exhaust did smell of gasoline. pulled a spark plug and it looked healthy, though it did have some gas on it. certainly not soaked in gas.
i've got the rest of the day booked, but I'll be back at it tomorrow. I'll start with spark and move from there. Whats everyone's favorite method of testing?
...the truck caught for about three seconds and slowly stalled out.
a new fuel pump is what you may be needing. last week i ran out of gas for probably the 7th or 8th time in the last year. i put some in and my truck ran okay till the next day when i was going for a dive on the other side of the island. about half a mile before i reached the spot i was going to park the truck lost power for about one second, reminiscent of running out of gas, but kept on chugging along to where i wanted to go. i waited for a bit then tried starting her up and each attempt resulted with the exact same symptom as quoted above.
get a fuel pressure tester to see if your pump is pumping at the pressure required.
the pump may be pumping but i think it is not pushing the needed psi or volume of gas to keep the truck running
I never was able to test the actual gas pressure, though I am interested to see. As I was chasing spark I found the coil to be faulty. Replaced it and I'm back on the road. I wonder if I ever did run out of gas....
Follow up:
So I swapped in a junk yard coil to get back on the road. I ordered a nice Accel Supercoil, new plugs, new wires and a new cap and rotor to be installed when I had time.
This morning was that time. As I'm doing the wires, the coil wire from the distributor cracks completely off of its burnt boot. What was left of the wire must have been resting on the distributor cap. Also found another plug wasn't getting any spark....
Yet the truck ran great the whole time. No hesitation, no stalls.
