- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
Agreed, a Jeep rear isn't really comparable, for the simple fact it's in the rear (where much of the vehicle's weight ends up going toward during launch/acceleration/climbing a hill). I've seen Jeep rears pop axles even behind the little 4-cyl.
A front D35 is able to tolerate more than a Jeep 35 simply because the exact opposite happens (weight shifts off of it during launch/climbing/etc.). However there still are limits to it (plus the fact it's low-pinion will work against you).
I s'pose you could always try it and see... Maybe you'll get lucky and it all holds together. If not, you can then start looking into other options.
