I've been hearing a little about pulse plugs. It sounds like they are a pretty simple upgrade, but I was wondering if there is a downside to running them over standard spark plugs. Input?
Technically speaking, the principle is sound. What they describe is possible with the electronics they list.
Will it result in better performance? Will it clean up the emissions? Will it "make" better gas mileage? Will it hurt the engine in the long term? No one can know until we have real world use experience, not just lab tests or anecdotal quotes.
Is it the correct design for our trucks? Not likely. That is why they have their other product.
When was the last time you spent $100 (4cyl) to $200 (8 cyl) on the spark plugs for your vehicle? They are $24.95 each.
Worth it? Not for me, but others may have different ideas.
The principle is sound, at least the effects of the larger kernel is sound. I don't see the mfgr "making it sound like they are creating power for free." From what I gather, they are making better use, and improving on power that is already there, not creating anything. shadySorry, the principle isn't sound! They make it sound like they are creating power for free.......total BS!!!
The described technical capabilities are within the parameters of the components. Upon further review, I would also question the longevity of those components in an enclosed heat bin. Capacitors tend to be heat and vibration intolerant without added stabilization in the package.
I say nothing about whether their claims are true. In fact, I question the veracity and accuracy of their claims. I also state that I do not think the gains (UP TO 9% claimed) are worth the cost ($24.95ea., msrp, per website) at this time.
These devices do not create power for free. These devices store incoming power to a certain device maximum level and, at a specific point, release it all at once. Think of a water barrier (gate or dam) suddenly releasing the entire body of water at once. That is the kind of surge (electrically speaking) these devices release.
Have you ever heard of CDI (capacitive discharge ignition)? That is what this is. These parts are using capacitive discharge on (and in) the plug itself, as well as in the coil. there is always a small amount of current attempting to jump the spark gap if the engine is running. That is what is stored. Up until this product, capacitive discharge has been used on the coil end only, with losses in the wire smoothing out and decreasing the spark.
