lift kit question
chazawazzle
washington state
i was wondering if you need to do any driveline, brakeline or carrier bering relocation on a 87 bronco 2 when installing a 4inch lift kit?
any advise apreciated.
You need longer brake lines, or relocated brake lines in the front, and you have to replace the stock CV rear drive shaft with a u-joint drive shaft.
cheapest and nicest = tough country
best/most complete = skyjacker class II w/ new leaves
yes, as do explorer rims....
yes same 5 X 4.5
also back to your first question I would highly recommend you trying to save for the skyjacker kit. It is far superior and in the end it really isnt that expensive.
Its "tee-you-eff-eff" (Tuff Country) ;)
Very good kit for the $$$, but not quite as sturdy as the Skyjacker or James Duff kits. I'd save just a bit more and get the better kit if you want to take it into rough terrain.
