- Feb 4, 2014
UPDATE: Re-thinking things quite a bit recently. Actually thinking IFS is going to be better, but don't know all that much about IFS under heavy weight.
Ok, for starters I threw the "offroad edition" in as a joke, because that adds what, a chrome bumper?
Introduction:
I'm a ~20 year old man from Indiana, to my left outside this house is a cornfield, to the right there is a cornfield, and straight out there is a been field. Good enough picture?
I'm a professional web developer, full time. But I've always been into cars/trucks/bikes just as much. I have access to many massive arms and a full blown auto shop to get the job done.
This will be my build thread.
I'm finally getting around financially where I can afford to do some major work to this truck.
Truck:
1999 Extended Cab, 4 door, ~182K miles
4.0 OHV with an Automatic (runs perfectly)
28 spline 4.10 on the back, some shitty 4.10 IFS on the front.
4x4 (vacuum hubs... They work sometimes
31s on stock 16" explorer-style rims (I like em!)
Intent:
I want a daily/semi-daily driver, the enduro takes over most of the summer so I'm getting 58mpg, but 30mpg through the winter in the truck sounds wonderful. Either way, raise it above 20mpg and I'd be happy.
I will not be trying to squeeze every last bit of power out of this engine, it's going to stay around 110-160 in the long run, that's good enough for my purposes.
I WANT WHAT I WANT
Also I don't want to end up doing a ton of fab work for every part of the truck, I can do it, but I don't want to be excessive.
I'm looking to swap a 4bt for my 4.0, then rebuild the 4.0 (even though it still is great) and buy roller to throw that and my old auto tranny in, then either sell/play with, whatever I decide.
First of all, yes, the axles must go. Looking at Dana 44s but don't think I actually need to go that heavy. Other options? I don't want to skimp, but I think the explorers 31 spline axles should do the trick. if I'm staying at a more mellow power, but should I use them? I'm leaning towards "HD is better" in all aspects of this swap.
What I know for sure is that both axles must go, and the front is going to a solid axle. What kind of suspension issues might I run into? Is there anything that sticks out as something not to do?
Transmission needs to end up attached to a rod sticking out of the middle of my cab's floor, i.e. I want a real transmission, and I want a manual.
What options do I have here? I'd like to use a Zf, but I think I only get one option for the small block version. I could go with something out of an F150, but again, heavier duty is going to be better. I just wonder how much fab work it'd cost me. The truck is going to sit about 3-4" taller because of how I end up doing the SAS, meaning I don't want a huge body lift to fit my transmission/transfer case underneath the truck. If there's one thing I don't want to skimp on it's my transmission.
Engine itself is going to be a tight fit obviously, but I have an engine crane and a pole barn with 3 auto bays and a 10,000lb lift, so this job should be easily manageable as far as space/brute strength to put the damn thing in.
What do I need to watch out for when buying one of these? I'm not dead set on buying a pristine, perfectly tuned and running engine, in fact I don't want that at all.
I'd like to purchase one that needs a little work, one that I can pour my sweat into and watch come to life. I'd even go as far as a total rebuild, but I don't want to end up with a cracked block or similar. I'm thinking I will buy one I can hear run, and hopefully avoid any catastrophic issues later on.
I've seen the build threads and done my research, this has been a plan for 3 months now. No one says much about the engine mounts. Why? Does she bolt right up? This is probably my most important question.
I don't plan on having A/C, I don't use it anyway. Windows are down if it's too hot, hell, windows are down in the winter and I use the heat to balance it out. This isn't a problem for me.
Fuel tank is another topic, but I can't imagine it's going to be a tough one in comparison.
I think I have the rest pretty well handled.
I'm looking to buy the engine itself next month-ish (gotta find a deal, we know how it is). Then I'll start with the rebuild on that engine.
Also, it's worth noting that I am taking an entire week's vacation to do the bulk of the work. I get vacation so why not use it, right? Aside from that I'm a pretty open scheduled guy. Work is 9-5 M-F, so I have plenty of time to actually do work on this truck.
The motorcycle will get me by for transportation during all of this as she has just seen a complete rebuilt, along with a new clutch, exhaust and so on
Current pic of truck:
Introduction:
Truck:
Intent:
I WANT WHAT I WANT
